-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Extra hose! not sure where it goes!!! (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/85568-extra-hose-not-sure-where-goes.html)
Bruce Allert 10-27-2002 05:42 PM
Help! Just put in injectors and had a hose left over. One end comes out of the right side engine tin just below the #3 injector (1.7). I didn't disconnect it but found it disconnected and can't find its mate. Anyone know where it goes? Pictures in all my books are no help.
thanks
bruce
3D914 10-27-2002 06:18 PM
bruce,
Check if the length is sufficient to reach a three-way valve. Two of these goe to each head (#3 cyl & #2 cyl), and the third one goes to the air cleaner housing. This is the configuration for the D-Jet on 2.0, and I'm suspecting its similar on the 1.7
You might also check the Tech Articles section as there are some diagrams for hoses, and fuel lines.
Good luck,
