pedal cluster painting
I need to put some paint on my pedal cluster base and am concerned about how it will hold up to possible brake fluid leaks. Is there a product/method of painting this to resist the fluid? The base (for lack of a better word) has only trace amounts of rust, and frankly, it looks like it would hold up pretty well without painting. What do you guys think?
'75 1.8 -->1911 |
Mike Ginter
If you want to color it somehow, POR15 or powder coat IIWM. And I'm still not sure powder will hold up to brake fluid. Haven't tried it.
Ginter's 914 stuff |
I disassembled mine, sandblasted, painted with Por15 and rebuilt with bronze bushings.
'74 914 V8 '70 914 |
The best way to keep brake fluid off your pedal cluster is to fix your leaky master cylinder.
Don Kiepert '73 Big Bore '02 GTI 1.8T Race a Porsche - There's more to life than left turns! |
You're welcome. The first time I rebuilt a pedal cluster after hearing and reading all the stuff about brake fluid, I wondered if it was able to "osmos" itself onto the pedals. Then I thought if that's the case, what does it want!
Bottom line - make sure your master cylinder isin't leaking and you can paint your pedals with freakin' nail polish if you want! (Plus you'll stop better)
Mike Ginter
My comment about how powder coat would hold up to brake fluid was purely hypothetical. If/when a MC does spring a leak (it does happen), it would be nice if to know you wouldn't have to re-powder the pedal cage also. I'm well aware of the fact that the pedal cluster assembly would never have brake fluid on it unless the MC is leaking.
Not to sound unappreciative, but "no kidding". AFTER I correct the leak, and put everything back together, painted and all, it is possible that the m/c may leak. I just thought someone might know of a paint that may be resistant IF it happened again.
Milt: I still havent phoned you yet (I live around the corner). Maybe on the weekend, I'm dropping the motor tonight for some rehab work.
'75 1.8 -->1911 |
Mike Ginter
Next time I'm powder coating I'll drop some brake fluid on a piece of coated scrap and let it sit for awhile...
Brake fluid wont hurt powder coating (you can still try it if you like Ginter)lol
B |
Mike Ginter
Experience is the best teacher you know...
Actually... this teacher in 6th grade named Kim Greer was the best teacher..LOL She gave new meaning to the Van Halen song (Hot for Teacher)
B |
