Bruce Allert's Avatar
ECU Plastic Surround
One of the posts How do I......??? asked about this adjustment. Brad mentioned the plastic surround has a mark where the factory set it. What is the position of the plastic surround? Mine has come loose and rotates. Anyone have a closeup picture of one?
thanks
bruce
Sit'n here
Hav'n a beer.
Punkin's gone
(sniff)
Gotta mow the Lawn...
Old 11-04-2002, 02:05 PM
pbanders's Avatar
Send a message via Yahoo to pbanders
I don't have a photo but will try to describe. The surround is somewhat "D" shaped. The flat part of the "D" is aligned with the long axis of the ECU and faces away from the ECU harness connector. It should have a key in it that locks it into a key slot in the hole where the pot is mounted.
Old 11-04-2002, 04:30 PM
Thanks. I found the mark on the knob and aligned it with the indent on the plastic while hold the plastic. I'll see how it runs. The last mechanic must've turned it too far. When I got it back he said he couldn't set it properly 'cause he didn't have a CO meter. Guess he had a really big screw driver! Just about twisted that sucker right off......
bruce
Sit'n here
Hav'n a beer.
Punkin's gone
(sniff)
Old 11-04-2002, 04:57 PM
