-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   ammeter gauge wiring (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/86320-ammeter-gauge-wiring.html)
hars914 11-04-2002 05:01 AM
I am installing an autogauge pro comp ammeter along with some
other gauges.The wiring diagram shows one wire to the battery
and the other to the B+ output wire from the alternator.
I looked on my 914 wiring diagram and the B+ wire is red and
goes from the Alternator to the starter. I hooked up the gauge
and nothing.Has anyone installed an ammeter and have the
proper wiring installation for a 914.Thanks
JWest 11-04-2002 05:52 AM
Are you SURE you want an ammeter? Voltmeters are usually a better solution. That is why automakers changed from ammeters to voltmeters years ago.
With an ammeter you have to have the primary feed for the electrical system running through the guage - dangerous and if the gauge fails your lose all electrics.
Voltmeters are in parallel with the system instead of in series. Much less current and less risk of a failure affecting anything else.
I believe that you have to run a wire from the battery to the ammeter, and then all other feeds to the car (except the big starter wire) have to come from the other side of the gauge.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
