-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Suspention query (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/86727-suspention-query.html)
chrisreale 11-07-2002 12:29 PM
Suspention query
Heres what I have: Koni Sport Yellows all around. 180# rear springs. I have the engine out, so when the old springs were on, the rear end was sitting high. Now that I wave the 180's on, the car sits about 9 inches off the ground (measured at both ends of the side valence). When the engine/tranny gets put back in, will the rear sit lower and the front end be higher?
korijo 11-07-2002 12:56 PM
Chris,
You will probably have to lower the front a bit. I have Koni reds w/ 160 # in the rear with the 1.7L in. Sits lower in the back.
Maybe we could test on mine first, then yours when the motor is installed. Just a few turns on a couple bolts up front.
Just a thought.....
Korijo:D
