Cigar lighter removal?
the socket, not the lighter itself.
![]() Are there any tricks or traps that I should be aware of when I try to remove it? tia, Lawrence |
Lawrence,
IIRC there's just a retaining washer that holds it in at the back. Then you just poke it through the front. Nothing tricky... unless you forget to unhook the hot wire
Chris H. '75 914 3.3 |
thanks, Chris. I'll pull that out this afternoon. I appreciate the response!
-L |
Mike Ginter
Hey Rusty,
How many wires do you have on the + terminal of the coil (on the /6)? Does yours have CD? Still have my number?
Ginter's 914 stuff |
