More Trailing arm questions
Brad (or anyone else)
Is their a fixture or any magical numbers printed to allow me to check if my trailing arms are tweaked from an encounter with a curb or ???? |
I believe that Haynes has a photo showing a couple of measurements. The trailing arm is in a vise as I recall.
--DD |
Re: More Trailing arm questions
There is no factory spec, or fixture to check the trailing arm off the car. If you see a dimple in the trailing arm where the sheet metal looks like it should be smooth, then it's definitely tweaked. I started making a fixture for this purpose after a crash, but never finished, since I have several spares. My plan was to make it sturdy enough to hold the trailing arm while I applied enough force to "un-tweak" it. |
| All times are GMT -8. The time now is 10:29 AM. |
