Relay board questions
I've stripped my relay board, cleaned it up, and soldered all the rivet contacts but now I'm having trouble finding Potting Epoxy. Any one know of a good Internet source to order from? How much will I need, a pint, a quart? Also should I fill the holes that go through the relay board before potting it or is the epoxy thick enough that it won't go through and clog up the terminals?
I ended up soaking my relay board in Mineral spirits overnight. Worked very well, just a little light cleaning to get the excess off with a pick. Thanks! |
I used liquid electrical tape to cover mine and it works fine for me. just a thought.
24flys |
I used the sealer in a tube called GOOP and let it dry for several days in the sun and it worked great.
Radio Shack (or Fry's, or other electronics specialty shop) should have potting compound available.
--DD |
| All times are GMT -8. The time now is 08:19 PM. |
