scg scg is offline
scg's Avatar
Targa Top Trunk Fit
So... In my old 914, the top just dropped right in and the lid just closed right up (once with the keys in it, but that's another story).
With my new 914, I have to jiggle the top around a bit (a lot) in order to get it positioned to close the lid.
Does anyone else have to do this?
Scott
74 914-6 2.7
Old 11-14-2002, 02:53 PM
Potter's Avatar
Send a message via AIM to Potter
Yea, I do too. My clips, both front and back, have chipped off and so the top can't "find the seat" without a little jiggling.
However, the targa top is kinda like the cap on a bottle of Jack Daniels........when your together with a bunch of friends and open it up you might as well toss the cap in the trash because you ain't gunna need it no more!!
'73 914 2.0
"Seriously Honey, the part was really really cheap...........honestly"
Old 11-14-2002, 03:10 PM
HarveyH's Avatar
I think you'll find the problem is that aftermarket replacement side window seals are made of thicker and harder rubber than the originals. (Don't know how the ones you might be able to get from a dealer will stack up.) They will make the top sit very slightly higher in the trunk when stowed and so interfere with the trunk lid.
Harvey
Harvey
Old 11-14-2002, 03:54 PM
scg scg is offline
scg's Avatar
Oh, yeah! I didn't think about that. I just ran out and checked... yup, new side window seals!
Problem found!
... and problem solved! (although I prefer Glenfiddich -- cask strength, of course!)
Scott
74 914-6 2.7
Old 11-14-2002, 04:36 PM
Bruce Allert's Avatar
I gotta fiddle about too... with the top . Maybe the GlenFiddich would help... in either case!
bruce
Sit'n here
Hav'n a beer.
Punkin's gone
(sniff)
Gotta mow the Lawn...
Old 11-14-2002, 06:39 PM
scg scg is offline
scg's Avatar
Okay, Bruce! First sunny & dry weekend of spring (above 50 degrees in Boring) I'll head up your way and we can "fiddle" with the tops of the cars and the scotch (I'll bring just a wee bi' o' scotch -- gotta drive home, ya know).
Scott
74 914-6 2.7
Old 11-14-2002, 06:49 PM
No need to bring the Scotch Scott... got it in the freezer await'n yer arrival!
bruce
Sit'n here
Hav'n a beer.
Punkin's gone
(sniff)
Old 11-14-2002, 07:05 PM
Problem Found, yes
Problem solved, no
Sense I replaced my targa side seals last year, the targa noo nonger fits well in the trunk. I have to push down real hard to get it to latch and I can't open it with the solinoid anymore. Fortunatly, I installed a cable to override the solinoid. The seals leak too.
Are there any correct side seals?
Old 11-15-2002, 05:07 AM
tneffhoe's Avatar
I would guess that your hinge pivots for the trunk have been replaced at some time, and installed a touch too low. You can unbolt your trunk from the hinges and install washers until you get the desired height/clearance. Another clue is that the trunk lid will sit lower than the surrounding quarter panels-not flush.
Old 11-15-2002, 11:46 AM
Send a message via AIM to mostrow
One other thought on the targa-in-trunk situation...
A trunk that closes with some difficulty over the targa top, but closes normally when the top is not in the trunk, can be caused by the reinforcements that are welded to the underside of the trunk lid. If these welds let go in spots, it causes the reinforcements to separate a bit and push down on the targa top. Sometimes they will rub shiny spots into the fiberglas on the top.
Matt O.
Old 11-15-2002, 03:19 PM
