Question 6 cyl. displacment changes?
Anybody ever done this or know someone who has - Change a 2.2E to a 2.7 and use the E cam and Weber carbs?
what do you think?
TIA,
Mike D.
Old 11-14-2002, 10:44 PM
Senior Member
I've never done it.
Nor would I do it.
It can be done, but the 2.2L case isn't up to the job. One problem is with the spigot lands. They are only about 5mm wide on the 3R case. As I recall, you have to bore them out 5 mm....which leaves
a 2.5 mm land. The 3R case also lacks the internal stiffening of the later 7R case.
The botton line, if you want a hot rod 2.7, start with a 7R case.
Since you would need a 2.4/2.7L crank, rods, 90 mm P/Cs, head work, case work (with the 2.2 or a 2.7L case), it's gets kinda pricey.
Better to get a 3.0L.....like I didn't.
I like my 2.7L, but I figure it's
life limited. If I get 3-4 more years out of it, I'll be happy.....sheesh, if I get 3-4 more years out of ME, I'll be happy.
JPIII
Early Boxster
Old 11-15-2002, 12:36 AM
The thing is I have a 2R case, and I've been told that it's a 2.7. I've read that it isn't easy. But I really need to find out what it is so I can set up the Carbs.
Oh well,
Mike D.
Old 11-15-2002, 10:31 AM
Senior Member
Humm.......
That's a different story.
It falls into the "what's done is done" catagory.
So you're trying to find out what size motor you have?
I assume you don't want to take it apart to do this.
You can check the stroke (roughly) I think.
Through the spark pulg hole with a pair of calipers.....the depth mic feature on calipers. Never tried this, but it should be possible with some fooling around.
66mm for the 2.2. 70.4mm (AIR) for the 2.4/2.7.
A strong magnet will be atracted to the Brial cyls ( the iron liners)of the 2.2...below the fins. The 2.7s clys are all aluminum.
Sorry for the bum reply.
JPIII
Early Boxster
Old 11-15-2002, 11:01 AM
It wasn't a bum reply. I just wanted to know if anyone had done to see if it could be done and what they did. I guess I was fishing for a response...
I'll try that thing with the magnet tonight. I'll let you know...
Thanks,
Mike D.
Old 11-15-2002, 02:50 PM
