sleepdoc's Avatar
Fuel Circulation
Hi All
My 3.2l conversion has the 911 fuel pump underneath in back. The fuel circulates fine and the pressures and volumes delivered are spec. The 914 fuel tank and its expansion tank are stock 74, and the charcol canister, and fume line to the induction are deleted.
When the engine is running if I look into the tank with a flashlight I see vigorous circulation. After the engine is warm, if I open the fuel fill cap there is the hiss of internal pressure from warm fuel vapors.
If the cap and fuel lines and the gasketed connection between the expansion tank and fuel tank are well sealed, does anyone see a problem with no fuel vapor escape system?
Best Mark
Old 11-17-2002, 12:59 AM
sleepdoc's Avatar
bump
Old 11-17-2002, 04:15 PM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
The gas tank is not supposed to be under pressure so I would hook the fume line back up to bleed off vapor.
Geoff
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 11-17-2002, 05:10 PM
