B Frye's Avatar
ECU Adjustment
Okay ... I've searched through the archives to find anything related to this but didn't have any sucsess.
The idle mixture adjustment potentiometer on the ECU (76 2 L) has no effect regardless of how far it's turned CW or CCW.
The engine is is good shape. No vacumm leaks.
I find it hard to believe that the pot has somehow gone bad. Has the ECU got a problem; or am I missing something related to external sensors?
Old 11-24-2002, 12:22 PM
bowlsby's Avatar
The ECU potentiometer only works at idle, or more exactly, when the idle contacts in the TPS are closed. When the TPS idle contacts open upon opening the throttle, the ECU enrichment circuits take over.
Are you sure your TPS is properly adjusted?
Old 11-24-2002, 03:13 PM
pbanders's Avatar
Send a message via Yahoo to pbanders
Like Jeff said, the TPS needs to be adjusted properly so that the idle switch is on when the throttle is closed. If the pot has no effect, then it could be the pot is defective. I've got an ECU in my collection with a dead idle pot, it happens to be an 052, the one used on the '76's.
Old 11-24-2002, 03:44 PM
B Frye's Avatar
Anyway to jumper the wires at the TPS to ensure the ECU is seeing an idle condition? I'm thinking this would verify the potentiometer is bad.
There are only 10 types of people. Those that understand binary and those that don't.
Old 11-24-2002, 03:55 PM
914 Geek
Yup, you can jumper those wires. I forget offhand which two they are, though...
--DD
Old 11-24-2002, 04:20 PM
pbanders's Avatar
You could. Instead, I'd suggest testing your TPS with the throttle closed to see if the switch is on, and if not, adjusting it. Here's the tech article:
http://www.pelicanparts.com/techarticles/914_cooley/914_cooley_throttle_switch.htm
If you want to jumper it, it's pin 17 to ground (pin 12).
Old 11-24-2002, 05:37 PM
