sleepdoc's Avatar
fuel overflow tube
Hi All
Can anyone tell me the routing of the fuel overfill hose?
It is the one that drains the shroud around the gas cap to the ground.
I see where it hooks to the vapor tank, but not the route it takes to the outside.
thanks Mark
Old 11-23-2002, 11:26 PM
madd_dogg_914's Avatar
Send a message via AIM to madd_dogg_914
It goes straight down after that. If you look on the passenger side underneath the car you will see a hole where it comes out. When I installed mine I had to lift the gas tank a little bit to get it through.
Hope this helps.
-Chris
Black, Blue, White, and Primer
Looks great anyways!!!
Old 11-23-2002, 11:43 PM
sleepdoc's Avatar
Thanks Chris
I will crawl under and look.
best Mark
Old 11-23-2002, 11:56 PM
