voltage for 3.2 fuel pump
Does anybody know how much voltage is supposed to be at the fuel pump? Using motronic brain. Also where do you find this information?
Buck
Old 11-25-2002, 05:52 PM
sleepdoc's Avatar
Hi
The 3.2l fuel pump runs off 12 volts. The power comes from the DME relay, the famous relay everyone is always replacing. This relay supplies the 12V power to run the computer when the ignition is on, and when proper conditions are sensed by the computer the fuel pump is energized by an output from the computer to the same relay which then supplies voltage to the fuel pump.
The best info is probably from the Bently 911 Carrera 84-89 Book
http://www.pelicanparts.com/catalog/shopcart/BOOK/por_BOOK_BKPTEC_main.htm
best Mark
Old 11-25-2002, 07:45 PM
Jim Smolka's Avatar
If you have a '75 or later 914, you can simply use the existing 914 wiring to power the fuel pump.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 11-26-2002, 06:41 AM
