brakelines, brokelines
I just took out my old MC and in the process snapped one of the brakelines at the fitting. Seeing that only about 1/4 inch broke off I figured I could flare the end and reinstall. It seems that the line is part of the small fitting? how would I go about fixing. Also what comes with the rebuild kit for the MC.
74 LE "Bumblebee" 03 Jetta Wagon |
I'd recommend against a m/c rebuild, but get a new one since it is the heart of the brake system. I would replace the line too since if it snapped than I would suspect the metal in the whole line? Good luck.
I'm with John on this. It is certainly easier and safer to replace the whole line than to trim it, flare it, and get it to fit on your back under the car. Most FLAPS carry pre-flared lines of various lengths and diameters. Get the old one out and carry it to one, it will save you a lot of work and come out better.
I won't express an opinion on the rebuilding of MC. I bought a new one (19mm) and a kit to rebuild the old one (17 mm). The kit and the old one are still on the shelf. |
johns right. don't be penny wize when it comes to brakes. the 19mm conversion is smart. the grommets that hold the two lines from the resivoir(sp) are a total nightmare. be warned.
72 911t grey/black mine 74 914 2.0 black/ tan hers 02 g500 black/black womanproof 01 f250 psd dirty the mule 60 correct craft starflite cool 69 correct craft torino hauls butt 72 correct craft ski nautique fun 66 vw 1500s will finish someday |
would not allow an edit....
you could try and reflare the line, but lines are cheap and you already have one end off. kill any rust while the mc is out. i think you need to bleed at the proporsioning vavle first on these cars
Dont re-flare it. Your time is worth more. Go to FLAPS and get one for less than $5.00.
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/ www.914club.com |
I'd go for a new brake line and M/C. This is chump change if you really think about what these parts do or what will happen if they fail when you "go for it" and nothing happens.
It surprises me how people will buy a 20-30 year old car and go for cheapest means available to get back on road vs. upgrading parts to "like new" condition when they fail. John
'73 914 (Renegade V8 conversion) |
Thanks for all the input. Xmas is here so under the tree I will have new 19mm M/C along with new brake lines.
