chrisreale's Avatar
Red face Me Stupid? Do I have my springs on upside down?
180# springs towards one end of the spring, coils are wound closer together. Should they be on top or bottom? Does it matter?
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/
www.914club.com
Old 11-26-2002, 05:08 PM
on struts i believe the tighter coils are on bottom. i'm not sure.
had you installed them the same way on each side, with your camber problem?
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 11-26-2002, 05:15 PM
korijo's Avatar
Chris,
From what I know, they should work either way. Just make sure that both are the same way.
IMO, coils closer together on top = softer ride; on the bottom = stiffer ride. Then again with 180 # springs, you wouldn't notice much.
I think?!
Dave
Korijo
73 Olympic Blue 914 1.7L (2L /4 back in progress)
69 Highlander Bug 1776
93 GL EV 2.8L The Van ™
914club.com Member #914
Old 11-26-2002, 08:52 PM
JWest's Avatar
Does not matter. The spring rate (and the ride) will be the same either way.
James
JWest Engineering
Old 11-27-2002, 06:08 AM
putting the tight coils on top would reduce the unsprung mass by a little. If it really doesnt matter, I'd go this way.
Old 11-27-2002, 10:39 AM
Unregistered
sammyg2's Avatar
I believe those springs are Austrailian, that's why the coils are upside down. No wait, if they were the coils would turn the opposite direction, or does that just apply to the water when you flush?
Sorry. I can't help myself.
I agree, doesn't matter. What does matter is that the springs are seated properly in the perches. Some aftermarket springs are shorter and don't like to seat just right. that can make the corner balancing way off. I used zip ties to hold my springs (200#) to the perches s that always sat just right, even after I jacked up the rear of the car.
Old 11-27-2002, 10:55 AM
RustyWa's Avatar
My "dead" coils are on the top.....for whatever it's worth...
Eric
'75 914 2.0L - Sold!
Old 11-27-2002, 12:32 PM
Kenny Powell's Avatar
Chris, actually you have 2 left handed coils, when you should have 2 right handed coils, or is it 1 left or 1 right? But seriously folks it does it really matter?
75' 2.0 w Ljet
"I like the way she doesn't move in the curve's... and then she let's go!"
Old 11-27-2002, 04:16 PM
