-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Anyone running 8" rear fuchs and GT flares? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/89086-anyone-running-8-rear-fuchs-gt-flares.html)
kellzey 11-28-2002 03:55 PM
Looking to see if anyone is running 8" Fuchs rears (911 offset) with GT flares?
What width tire are you running?
Did you use a spacer?
What length studs?
What about the front? Are you running 7" Fuchs in the front? Same question?
Just looking for the correct stud/spacer combination to fill out the flares?
Thanks,
evill 11-28-2002 07:31 PM
Karl, I run 8 x 15 Fuchs on the rear, with 1/4-in (7mm) spacers and 225/50/15 Yokohama AVS. No problems. My track wheels are 9 x 16 with 245/45/16's which also fit, not by much, but they do fit.
Fronts are 7 x 15 with 225/50/15 Yokohamas also. I run 1-in (25mm) spacers with 65 mm studs.
I have standard length studs on the rear,
I don't recall the size, (54mm ?) Standard 911 rear size.
Ed
rich 11-28-2002 10:08 PM
1 Attachment(s)
I have 215/60 Yokohama A378's on 15" X 8" Fuch copies with 25mm wheel spacers on the front. I have 235/60 Yokohamas on 15" X 8" Fuch copies with 25mm wheel spacers on the rear. Glas GT flares. I could have used a thinner spacer on the rear like the others. I think I installed 75mm studs. I can't really remember. I did the conversion many years ago now.
finadict 11-29-2002 08:37 AM
1 Attachment(s)
Pictures of my 914 16x8 in the rear 225 50 no spacers have about 1/2 inch clearance between tire and flare. http://forums.pelicanparts.com/uploads/914_RR.JPG http://forums.pelicanparts.com/uploads/914_rsf.JPG
John2kx 11-29-2002 06:04 PM
Finadict,
Just when I thought the 16x7's were gonna do it for me, I see your car. Nice job!
Are your rear flares glass or steel?
What did you do for side rocker panels?
How did you mold/cut the openings for exhaust on rear valance?
Are those 6's or 7's up front?
John
finadict 12-12-2002 06:53 PM
John
Sorry for the delay in answering, I believe they are 7s up front. The rear flares are glass, the rocker panel and rear valance I made to match the lines on the flares.
chrisreale 12-12-2002 07:30 PM
finadict, are you from the NW? Like Seattle? Id love to see your car in person!
finadict 12-13-2002 07:13 AM
Not a problem, I'm in Gig Harbor. Contact me by email and I'll give you the directions...
