I'd like to install metal rollers on the rear trunk torsion springs but pulling those bars back looks dangerous. Tech Tips 700 describes (somewhat unclearly) a procedure involving a 10mm wrench and a Crafsman cheaterbar with a "c" shaped notch at the end. But I don't really understand what Tech Tips is talking about. I don't want to have to buy weird or exotic tools to do this (I think as was mentioned in a previous thread).
Little help please. Douglas |
Administrator
Lots of ways to skin this particular cat.
You can get a bar and grind a notch near the end. Use the notch to capture the torsion rod, use the bar to push the rod down. You can make the "Ricky-Do torsion spring tool" as detailed in the Tech Articles section of this site. You can use a box-end wrench or two on the end of the rod. You can use a deep socket, about 1/4" size, with a long extension. Put the socket over the end of the rod and use the extension to push the whole shebang down. Whatever you do, I suggest wearing heavy gloves. May save your fingers if you slip. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
They are dangerous. In addition to gloves, I suggest good eye protection. I've done two without incident, but I was plenty careful and nervous about it. I made my own tool for the job.
I know of a couple people who sell pneumatic strut kits for 914s that replace the springs, might be worth looking into. At one time Pelican offered the kits also, not sure if they still do. |
I went through this recently, and came up with a beautifully simple solution that doesn't require you to modify or fab anything. I used a 12" long Craftsman 3/8" drive socket extension. The 3/8" drive hole in the end of the extension fits the end of the spring very nicely. You can use this to lever the spring down while removing the pulleys without any difficulty. Just make sure that you press the extension down onto the spring tightly so it doesn't slip out while you're doing it. I submitted this to Pelican as a tech tip, but it hasn't made it onto the site, I guess.
Stay away from my Member
What (else) is involved if you want to completely remove the torsion springs/bars?
When I remove the torsion rods to install the original CAMP 914 rear trunk shox kit. I do it with gloves and eye protection on and a large, long(the longer the better) flat tip screwdriver or pry bar. First thing is to remove the white cups in the rear firewall area so that you can access the 10mm nuts that secure the torsion rods. This is a good time to put a broom handle or something to support the rear trunk lid because we are going to be taking the tension off, that means it could drop down rapidly.I use a heavy movers cloth is best. Put the blanket at the area where the roller is located, what can happen if you don't is that the roller could fly off. What I do next is not for the faint of heart. Blanket is in place, take the long large screwdriver a pry the roller off of the rod on the trunk hinge by prying on the torsion rod itself. I know this sounds crazy, but I have done 12 this way and have not had any accidents or injuries as of yet, but I am also careful and I wear proper gear, and I am always nervous when I approach this phase of tension rod removal 101. It is noisy but over very quick.
I then remove the 10mm nuts and remove the tension rods, be careful, do not touch the rods on to the battery, good idea is to remvcoe the battery if in the stock location completely. One more thing the early cars72 and down have as loop that is welded in place and makes it more difficult to remove the rods once the tension hasd been released, the strap needs to be cut and the rods slipped out and then taken out of the engine compartment. Craig C. Laughlin CAMP 914
Craig C. Laughlin CAMP 914 Helping to bring your 914 into the 21st century. http://www.camp914.com |
What bob174 said.........takes about 1 min per side to remove and replace. Oh and the gloves and glasses thing? By all means.................cuz if sumthin lets go while your there..........
Craig. "Don't close your eyes before the crash....you'll miss the best part!" |
Administrator
The one time that I completely removed the torsion rods from the car, I did it by cutting them. That relieves the tension on them very nicely.
Then it's a simple matter to remove the brackets and throw the whole mess away.It was made easier by the fact that there was no drivetrain installed in the car. Oh, and of course we were cutting the thing up (see "Sawzall party") at the time. ![]() --DD
I would only add a trusting younger brother to the process..."ok dude.... when I push down you slip this on that part right there...quickly "
Cheers, Scott 1973 2.0l ivory 914 1962 sunroof bug 1966 std bug 1990 WE Vanagon CARAT |
Thanks to Dave, Bob, and Boxter
Thanks so much to Dave, Bob, and Boxter. I installed the brass rollers without hurting myself. I used a variation on Dave and Bob's ideas to use sockets and/or extension bars to push the spring down. It turns out that a 5/16 socket (I knew those standard sockets were good for something) slips on to the end of the torsion bar perfectly. The snug fit makes it hard for the torsion bar to slip out. Then I attached that handle fitting that looks like a screwdriver, except that instead of there being a flathead or philips on the end, there is a 1/4 inch drive. So you attach that to the socket and you have a very nice and snug prybar. I had to remove the oil tank filler tube (came off without tools) to get to the left side spring. Pack the rollers with grease and slip them on. Damn, my trunk rides smooth!
Thanks again PP Tech Forum. Douglas |
O.K. moving the springs in order to slip on some new trunk rollers is not such a big deal...
But what do I have to do in order to tension the spring from its neutral position back to the roller??? I read the Tech Article but... ...the "Ricky-Do torsion spring tool" is nice but I do not have the tools in order do fabricat one of those. The jack handle idea sounds cheaper but I do not understand how I could attach the jack pipe while turning the torsion spring about 150 degrees... on my car I have a a bunch of sheetmetal in my way. I have a backup plan which includes welding a hex nut on the torsion spring to allow the utilization of normal handtools... ... but that would not be pretty! Who has a good idea to put that torsion bar back into place???
'74 Porsche 914 2.0l '90 VW Vanagon 1.7l Diesel |
I made a tool for leveraging the torsion bar into place out of 1/2" square tubing. Get a piece about 18" long and cut off about an inch. Weld the short piece on the end perpendicular to the long piece. Slip the short piece over the end of the bar on the opposite its hinge and use it to rotate it into position, then tighten the clamp down (have the other side already clamped down. It helps to have someone hold it in place while another tightens the clamps. I did this with everything out of the engine compartment and no engine cover so maybe normally something would be in the way. But the tubing let you get good leverage at right angles to the bar.
Thanks to 914 GT I did it!!! The critical hint was "on the opposite its hinge and use it to rotate it into position" ... It never crossed my mind to mess with that side. Cool! Thanks again!
Oh... and it works with all esential parts installed in the engine bay.
Yoh!!!
Great news. Glad no smashed/broken fingers or scraped knuckles. I think the only thing worse than the 914 trunk is adjusting those old-style garage door springs. For those I would always pray 'Holy ***** I hope this works! |
Thanks to all for contributing. When I bought my 72' 914 it did not have springs for the rear trunk. I bought the torsion springs and brass rollers. I used the box wrench with a crescent wrench method mentioned here. It was a very difficult task until I had a friend help me. I used the box wrench and crescent wrench while he used a screw driver to work around obstacles and guide the spring onto the roller. Once he helped me it went quickly. Now the torsion springs are in the one side of my trunk is out of alignment and sticking up high. Anyone have any advice on trunk alignment. Thanks again everyone!
Torsion bars put great stress on the hinge mounts which is why a lot of teener owners ditch the torsion bars in favor of the gas shock setup.
Ron Meier Backyard Shadetree Mechanic 1974 914/6 conversion with 2.7L (The Grey Ghost) 1973 Chalon with 2.4T MFI (Schlitzalom) All my 4 cylinders are gone
Thanks Ron. The hinge mount is torn from the body. I ordered a new mount from Pelican.
Wingnut86
Dave D.,
This is so simple ![]() Leverage your inside connections here at The Bird, and get Plymouth57 from TheWorld a free Porsche tour for hos college internship ![]() Duh. Now, creatively convince him to build those nice tube rear-ends and flip up backend at a nice price point "Distributed by your 914 friends at PParts". Then, you archive the string above in the "Ancient Fix" file, as 85% of the teener world will be standing in line with money from the Cash-for-Titles, Cash-from-Credit-Cards, 401k cash-outs, kids piggy banks and selling their wive's and partner's Priuses. All just to have their own Ease-of-Maintenance Type 47... Sorry for the Hijack, but if you don't know what I refer to then Dave can supply the build link for all to drool over... ![]() ![]() Good luck - wear chain male... Dave B.
1976 914 2.0/Roller - Jack-stands and Drip-pans 1970 914 1.7 - Tarped and Parked 1972 914 1.7/Roller parts donor for the Twisted-Sisters above ..."...what we've got here, is Failure to Communicate..." |
