DuckRyder's Avatar
Send a message via AIM to DuckRyder
Weltmeister "Short Shift and Lockout"
Perhaps this is a bit premature since my "good engine" is still in the floor, but:
Do these two kits work togeter or does the short shift kit include or negate the need for the lockout kit?
Robert
1975 Porsche 914/4-2.0
1972 Ford F100 Ranger XLT
2006 Ducati Sport 1000
323i.net
RangerXLT.com
Old 12-04-2002, 06:36 AM
canna change law physics
red-beard's Avatar
You can use both together. Are your springs really weak? Is your lockout plate really damaged? Most of the time, all you need to do is adjust the shift linkage.
I have not seen the short shift kit, but the stock shifter has a couple of internal bushing which wear out and create tremendous amount of slop, which is most noticable when you are in gear and can still move the shifter significantly from side to side. If the short shift kits replaces these with new ones or get rid of them, it may be the reason a short shift kits helps sloppy shifting.
To replace the bushings and the spring for the standard shifter is about $45 but are available only from a Porsche dealer.
At the end of my tranny article, I show you how to adjust the linkage and also list the shift selector bushing and spring parts.
http://home.san.rr.com/pb914/rebuild/
Both sides of the lockout plate should be straight (well, except for the obvious notch at the end).
James
James
Red-beard for President, 2020
Old 12-04-2002, 06:48 AM
