bowlsby's Avatar
914-6 GT Restoration webpage
Know German?
http://www.auto43.de/914gt/01/914gt01.htm
Old 12-05-2002, 11:42 AM
sammyg2's Avatar
On the last page it says "fahrvergnuegen".
don't they realize that the 914/6 isn't a VW? :-)
(ducking for cover)
Old 12-05-2002, 12:31 PM
bowlsby's Avatar
That word translated means:
'Drive-pleasure'
So....fahrvergnuegen!
Old 12-05-2002, 12:37 PM
Translation (literal)
Page 1:
The body of this vehicle was already restored and painted before 10
years. Then the owner began the adventurous search for the rare GT
sections and rebuilt the vehicle. Now is it so far - the car is
drivingready and the last handles and checks pends.
Page 2:
Einige of the GT specific sections and special features:
On the right: Cathedral props in the trunk down: mechanical pig
thrower operation down on the right: the large tank
Page 3:
Left above: Overroll bar and on the right bowl seat above:
felt-referred instrument panel at the bottom left hand corner:
Emergency power switch down on the right: Hood opener
Page 4:
Special features outside:
Left: Catches for the front hood at the bottom left hand corner: the
opened front hood down on the right: punched hood hinges
Page 5:
******Oben left: Tank opening in on the right front hood above: Openers
for the engine cover ***Unten left: through-punched engine cover down
on the right: Catch of the rear flap
Page 6:
**Der oil cooler - correctly inserted is half cooled... On the right:
Frontal view of the radiator inlet center left: low-cut front sheet
metal for air intake with lattice center on the right, at the bottom
left hand corner: Soil window for ventilation shaft (output) down on
the right: inserted ventilation shaft. The ventilation shaft is
available in the trade out of plastic or sheet metal (as also in the
original). In addition, build is problem-free possible
Page 7:
The oil cooler - line process at the vehicle original wiring
- screen sequence in "read direction" - from workstation and assembly
run the lines base first from the trunk into the interior and from
there by (the one which can be again cut out) a hole in the rear left
being wall at the Aussenschweller. Fixed at the Schweller along the
lines finally run to the rear of the vehicle and into the engine
compartment.
Page 8:
*Fahrwerkeinstellung: The chassis of a completely dismantled and again
assembled vehicle must again be adjusted on an oh measuring status, in
order to ensure an optimal handling. This protects the lowest possible
tire wear and an optimal measure to driving safety in the
kurvenverhalten and a clean keeping in track regret.
Page 9:
*Fahrvergnuegen are called in English by the way "drivingdivert" last
handles of the owner personally: Number-describe screwed on and then
kann's loose-go...
Brian Miller - Scottsdale, AZ
1962 Devin C :: 1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S
Old 12-05-2002, 12:40 PM
JWest's Avatar
mechanical pig thrower
Cool! Did at GTs have mechanical pig throwers?
James
JWest Engineering
Old 12-05-2002, 12:54 PM
Just a computer translation from Sherlock... I have no idea how accurate it is.
I suppose it would be like trying to translate someone riding a HOG (harley) into german... it wouldn't make sense either.
Old 12-05-2002, 02:03 PM
JWest's Avatar
I can't stop laughing when I read that. It's just really funny to me!
Oops, and I meant to say - did ALL GTs have them.
James
JWest Engineering
Old 12-05-2002, 02:08 PM
Senior Member
I'm holding out for the updated electro-hydraulic pig thrower or EHPT.....widely used in the professional pig throwing competitions.
Pig catchers are generaly fitted with baseball type catchers masks, but modified with plexiglass to keep the "pig spray" outta their eyes.......this is considered the "s****y job" at these events.
Catchers use the term EH, PhhhhT !!! upon receipt of the flying porcine missile.......thus the origin of the word "epitaph".....wait, I have more....
JPIII
Early Boxster
Old 12-05-2002, 02:26 PM
sammyg2's Avatar
What happened to the good old days when we used catapults to throw our pigs? Heck JP, when I was your age....... Ok maybe not :-)
Yup, I cracked myself up again, but you started it.
Old 12-05-2002, 02:32 PM
sammyg2's Avatar
Maybe they were talking about a Gunea pig thrower like in this article: (is it Friday yet?)
Guinea pig throwing ban
Press Association, 29 September 2000
The New Zealand Education Ministry is cracking down on animal cruelty after two secondary school teachers at a conference were caught throwing guinea pigs. It has brought out a new document, Caring for Animals - A Guide for Teachers, which explains proper care techniques for pets. The teachers threw the animals to protest abot changes in education policy. A spokeswoman for a local Guinea Pig charity told Press Association: "You saw what they did? It was bloody ropeable! I want their heads on a stake, the two of 'em"
Old 12-05-2002, 02:35 PM
Paul_Heery's Avatar
Send a message via AIM to Paul_Heery Send a message via Yahoo to Paul_Heery
Nope, definitely a pig thrower. This one's got too much torque for Guinea pigs.
Old 12-05-2002, 02:48 PM
