LinkBack | Thread Tools | Rate Thread |
Clutch cable removal
Rob Watson Red '74 2.0l |
watsonrx13,
The u-shaped connector (#10 in picture) wraps (locks) around the threaded shoulder of the cable end (#9). It should pop off - pivoting on the pin. Then the pin slides out of the arm (#34). Sometimes you may need a small screw driver to pry the u-shaped connector up. That releases the cable from the cluster. The snap-off ball is for the throttle cable (on the 914). I think this article tried to cover other models, but there may be some slight differences. The picture below is of the 914 cluster. I've followed that particular article, so it does work. Keep at it.
Gerard 74-914 White - Soon to be a custom 3.2L Six ![]() ![]() ![]() |
Thread Tools | |
Rate This Thread | |
