LinkBack | Thread Tools | Rate Thread |
Camber Plates
Qarl |
If you replace the top mounts with essentially a solid mount then guess what absorbs the upwards shock, the sheetmetal has to. Normally this is a good idea for race cars which see lots of inspections and maintenance but street cars may get some torn metal? There was a post a little while ago showing the replacement of the inner fender sheetmetal for a race setup and that is what you'd need.
Wouldn't the shocks absorb the "shock"?
Qarl |
Karl, IMHO, normally yes. But John and others are using a real stiff shock, so more of the energy goes into the body, hence the harsh ride. Also, you ask what additional benfits to the mono balls. There is a little bit of lateral movement in the top of the shock, both front and rear or no bearing would be necessary. I'm thinking that a tiny amount of binding is eliminated. But I think the main two advantages are maintaining steering geometry and positive shock reflex action by elinminating the rubber which is counter-productive to the shock valve. Now that's about $.01, hah!
The way it was explained to me was that the initial shock of a bump right when the suspension is changing is felt by the lower mounts, if any and then the upper mounts and then the internal hydraulics get to working and do their job. This happens in nanoseconds so most of the time we never notice it. If the car has some stiff shocks and maybe 205 Victoracer tires and the after market upper shock mounts there is still some shock absorbsion taking place, but use Goodyear slicks with very stiff sidewalls and Koni sport shocks then the suspension gets nearly solid. I'd use something like the solid mounts if I had everything else done and needed just another 0.1 of a second off my Willow Springs lap times?
I have the Weltmeister top mounts and use the car on closed road rallies. They make the steering feel more precise and I can get a bit more negative camber on the front. I wont be going back to the rubber things. Driving around normally they are fine.
They keep my alignments where I want. I dont need the camber changing when I go into the corner as I load and unload each side.
The bottom Welt is better than the top. The bottom one allows you some more negative camber with the second set of holes without cutting the tub. When I use the top one... I have to cut the tub to get more negative camber. Less friction during turning (on the shock shaft) not much.. but some. They impress your friends when you pop the hood... lol It makes the shock actually work instead of the rubber dampening the intial movement during bump/rebound. Take that... and that... B |
Does it make me a bad pesron if I would buy the weltmeister on looks alone?
Robert 1975 Porsche 914/4-2.0 1972 Ford F100 Ranger XLT 2006 Ducati Sport 1000 323i.net RangerXLT.com |
Yeah.. what sucks is you have to install them and you cant really see them after that.
B |
Thread Tools | |
Rate This Thread | |
