RETIRED
Hello boys and girls.....8^)
The kids (Katherine 8, Kristen 8, and Danielle 6) are all a twitter, the house lights are up as well as the tree's......the wife is out shop lifting and I am finishing up the sanding of the oak dining room table and two leafs. Stoopid thang has some weird "smog weenie" required coating on it that balls up and clogs even 40 grit sand paper. Once thru it gives me good sand dust......120 grit followed by 220 gets the job done. Got BOTH sides of the famn damily coming over for the 25th......should be in excess of 20 ish peoples ....depending on who is out on bail....at least MY side of the family...... I also got to fix/improve the 3.6 powered Sooper Coupe.....my buddy Ingo came by and said.....Dood, have you checked your wide open throttle? HUH? Well we popped the lid and I pressed the gas pedal.....then Ingo pressed on the throttle body linkage.....hhmmmm, another 1/2 inch......2 ten mm bolts and a grinder later that stoopid stop in the gas pedal problem was gone.....BUT, when I step on the loud pedal.....the rear wheels spin.....bummer.....gotta get stickier/bigger tires.....8^) Now waiting on the next storm to pass thru.....the new garage up on the hill has the pad dug, we are waiting on this round of rain to stop and get some foundations dug.....then the 12 foot back wall to keep the stoopid hill from falling down......then we can do the rest of the stuff and I can have my Ozzy collection up there and crank it......should be able to pizzoff my elitist duffist neighbors off in one easy lesson......the weasels up the hill have NO kids, drive leased whatever is trendy, and hate anyone that stoops to working on their own house......so I be on the low life list..... Hope to have the 356 and the 914 up there for the winter to do the rusto work on the pan and the 6 conversion on the '14..... Anywhooooo, ALLZ you guyz and girls have a SAFE and happy holiday. Mike Z, daddy of three gorgeous gals.. 9 Eleven Motors, CA licensed and bonded dealer 65 356 C Karmann Coupe #219593 73 914 2.0, Karmann Targa 83 911 cab, 3.6...duck tailed and going retro. http://www.9elevenmotors.com/ |
