Engine Doesn't Crank Over Issue
Not sure what to check an looking for pointers.
Ran fine this morning in garage, every thing worked. I had the fuse panel unmounted as I finished installing the DPD under dash blower and tied into a wire position that comes on once the key is on. Put it all back together and now it doesn't crank. Weird. Battery has a charge. Just wondering what the culprit might be. When I turn key on, I used to hear a funny little noise, kinda like a little spring that was pulled, but now I don't. Possibly the issue? |
Update
I have a loose connection somewhere. Messed around with the fuse panel relays and then, the little click noise I hear when I turn the key on was heard again. Engine started right up. What is that thing that clicks when the key is turned on as it seems to work and not work as it wants. So I figure I'll change that out and clean more connections thanks |
| All times are GMT -8. The time now is 06:55 AM. |
