kellzey's Avatar
914-6 engine oil cooler
If I understand correctly, the 914-6 engine cooler is a slightly modified version of the standard 911 engine oil cooler. I think there is a 90 degree fitting on it or something along that line.
Can someone please clarify/explain this.
Can one take a 911 engine oil cooler and cut off and weld a new fitting to make it functional for the 914-6 engine/oiling system.
Is there a certain year cooler I need to look for or are all the coolers the same?
This will be for a 3.0L motor.
Thanks,
Qarl
Old 12-21-2002, 08:21 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
You've pretty much got it right. Check the "914-6 conversion" section of this website for a little more detail.
--DD
Old 12-21-2002, 08:41 PM
kellzey's Avatar
Dave,
I checked the section, and it really only talks about the two types of oil tanks and associated lines and accessories, but not really about the engine oil cooler itself. Unless I'm missing something.
Happy Holidays...
Qarl
Old 12-21-2002, 08:46 PM
Senior Member
BAsicly, the cooler is modified so the intake fitting faces fwd.
Here's crappy pic.
JPIII
Early Boxster
Old 12-21-2002, 09:14 PM
kellzey's Avatar
So to answer my question...
Since I am building a motor from a longblock and need a cooler from my six conversion, I can pick up a good used Behr engnie oil cooler from a 911 and have it modified? Right?
Thanks for the help!
Happy Holidays,
Qarl
Old 12-21-2002, 09:18 PM
Senior Member
Ayup, Otto's did mine. Bout a buck 50. They clean and test, do flawless work, and have good service.
Or...
You can saw it off and hose clamp a piece of radiator hose on there.
JPIII
Early Boxster
Old 12-21-2002, 09:40 PM
Jim Smolka's Avatar
Since the line is the oil feed to the motor from the tank, a 90 degree AN 16 fitting is welded onto the 911 oil cooler of my 3.2 motor. Then, a SS AN 16 lines go to the aftermarket oil tank. Maybe over-kill, but it works.
The trick is to insure that the fitting does not stick out too far and hit the trailing arm.
Instead of using AN fittings, another option is to use the S hose from a 911 to connect the oil cooler. As mentioned earlier, you will still need to cut off the end of the cooler inlet pipe.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 12-22-2002, 02:57 AM
Senior Member
What Jim says is true.
For an OEM tank, it's easiest to stick with metric threads.
Which do you have?
JPIII
Early Boxster
Old 12-22-2002, 06:59 AM
ss6 ss6 is offline
ss6's Avatar
I had my cooler modified by Patrick Motorsports to pick up an AN-16 line.
FWIW, Pegasus sells a couple of AN-to-Porsche adapters specifically for oil cooler setups; you may be able to avoid the welding. But to Jim's point, you'll have to be careful about clearances.
John
Yellow '76 914 3.2
YPAF
Old 12-22-2002, 08:24 AM
kellzey's Avatar
I have a factory tank, and I will also be running an external cooler in the front.
Qarl
Old 12-22-2002, 08:33 AM
