ruddyboys's Avatar
pain in the pedal cluster
Just starting a pedal cluster rebuild. Tried to tap out the roll pin and it doesn't budge. Go to drill it out with new metal drilling bits and it drills about 1/8 and just seems to spinn. Try the other side and the same 1/8 and stops. any suggestions.
74 LE "Bumblebee"
03 Jetta Wagon
Old 12-22-2002, 08:11 AM
Put it in a big vise, apply heat, punch and big hammer. I broke several drill bits before taking it to local Porsche shop. They used the above technique.
Old 12-22-2002, 09:00 AM
John Rogers's Avatar
If it is spinning then it is loose and as noted it will come out with a punch and a large hammer. I found a punch the right diameter at Harboe Freight for $3 and it works great. Good luck.
Old 12-22-2002, 09:34 AM
jamcleod's Avatar
Send a message via AIM to jamcleod
mine never did come loose.... left it and went on
Old 12-22-2002, 03:50 PM
thesey914's Avatar
Jamcleod -mine also refused to come apart. Tried everything punching it, heating it, drilling it ( drilled it right through )-in the end gave up and put it back in the car. And I HATE being defeated
Old 12-23-2002, 02:49 AM
You have to make absolutely certain that all the holes are lined up as you use your punch and big hammer as suggested. Even a fraction of a fraction and the little bugger will hang up. I've done a couple cluster rebuilds and lernted the hard way! Hope that helps.
Don
Don Kiepert
'73 Big Bore
'02 GTI 1.8T
Race a Porsche - There's more to life than left turns!
Old 12-23-2002, 11:05 AM
