Koni front strut adjustment
Hey guys..
I need to reset my 911 front Koni's. Which way is stiffer and which is softer??? I did a search but I am getting conflicting answers. The Koni's are from a '74 911 and need to be removed to be adjusted. Is this correct???? It seems like 1/2-3/4 turns from the full soft position is what most are running for a street application. Thanks
Kerry (Back on the road, sort of) 914-6 in the Werks |
All the Konis I've seen have the stiffer/softer arrows stamped on the tube.
Dont know, mine are externally adjustable
If you need to, Jason at paragon products could probably help. www.*****************.com
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/ www.914club.com |
I used to know bout this, but I fergit.
Full soft is best, bye
JPIII Early Boxster |
