fuel pump question
iI am changing from carbs to fuel injection ( yeah!!!!!!) I have worked with djet on my old 914 and now am working with Ljet - question is is the fuel pump the same one. from the looks of the pic's in the manual (haynes) and the bosch injection book they are diferent but the description is the same. Can anyone help me with this???? tha
renee 71 914 65 fstbk mustang 97 "burb" 94 pic um up |
As long as the pump in question will pump the required flow and maintain the correct pressure, the system doesn't care what kinda of pump it is.
Pre 75 fuel pump: Flow minimum - 13.2 gph Pressure - 34 psig Post 75 pump: Flow minimum - 16.4 gph Pressure - 35.7 psig According to the Haynes gods. Requirements are for both L & D jet. I believe the "smog cars" ('75-'76) used more fuel to make cleaner air.
"Inventor - Blue Flame 914 Seat Heater" "Yellow Rusty Cars Are Faster" _____________________________ '70 2.5 (I'll never finish it - Somewhere over the rainbow.....,) '73 2.0 (Just Not The Same) '74 2.0 (Heartless & Lungless) |
Mike Ginter
They're not the same, but as Ron said, one will work as well as the other.
Ginter's 914 stuff |
fuel pump question
thanks guys one more question pic in book looks like it has two hoses (fuel) the one i have has three hoses marked s, r, d. i have the schematic for who goes where and stuff .... still no biggie???? ron got snow in crestline???? grew up down in s.b.
No snow yet - not cold enough. I'm at 5000' ~ sno level was above 7000.
Without getting my manual - (it's 5 AM and I can't see) - S= Suction (from the tank) R = Return (to the tank) D = Pressure to the system (don't know the bratwurst word)
fuel pump question
Thank you
Druck - bratwurst word on oil pressure gauge in 911 so I think it means pressure.
bringing back an old thread
I have a 914 that's been a huge money hole, and I'm looking to get rid of it, the mechanic has told me it's the fuel pump which has gone bad. Earlier in the post a member listed the fuel pressure and flow ratings for the different fuel pumps. Will a 75 pump wokr on a 74? It's certainly not an ideal solution, but I WANT TO GET RID OF THIS ONE. Please help me if you can as this has simply gotten too expensive.
money hole? check ebay for pumps, certainly under $50 i think. If not, I have an early and a late pump, you can have your choice.
You could just give that money hole to a charitable cause- me. PD
72 914 2056: 74 9146 2.2: 76 914 2.0 |
