ben ben is offline
Question fuel tank inlet outlet gaskets
I pulled out my fuel tank on my 72 mainly because it was showing signs of minute leakage around both the inlet and outlet tubes. So while the tank was out I flushed it and removed both nipples. The outlet has a screen that includes an aluminum gasket base but it looks as though there is another gasket made of a non metalic material that goes on as well. The return line has just the non metalic gasket. I found some copper gaskets in an engine rebuild kit that would fit. I was thinking of using these gaskets and some pipe thread locktite. Anyone ever mess with this?
Old 12-24-2002, 12:28 AM
10 914's and counting
ctc911ctc's Avatar
I am installing a freshly refurbed gas tank into my '74, same question......gaskets best for the application?
Old 07-08-2018, 12:27 PM
Be sure to replace all gaskets associated with fuel distribution and supply. Use the same material, and use caution when removing/replacing the bolts. They are easily broken during installation. Again, try 914Rubber or *********** for parts.
Old 07-08-2018, 04:01 PM
