chrisreale's Avatar
oil temp sender and gauge
I searched the past archives, but I want to clarify my question in the present. I removed the stock oil temp gauge from the center console in my 73 2.0. I put in an aftermarket VDO cockpit oil temp gauge #310012. I need to replace the stock oil temp sender with VDO-323055, right? Thanks
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/
www.914club.com
Old 12-25-2002, 12:48 AM
Never left, but not right
Zeke's Avatar
Yes, I believe they are sold as a set. However, DD says the stock ones are made by VDO. The real question is do you want to trust a 30 year old sender?
Old 12-25-2002, 11:29 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Yup, that's all correct. The stock ones are VDO, but the range is wrong for any of the popular aftermarket gauges.
--DD
Old 12-25-2002, 08:17 PM
chrisreale's Avatar
There are three wires that plug into the rear of the gauge. One is from the sendor, one is grounded, and the other..?
www.914club.com
Old 12-25-2002, 08:32 PM
Stay away from my Member
campbellcj's Avatar
IIRC the other is a + lead for the gauge illumination; should be switched by the parking lamp circuit ideally.
Chris C.
1973 914 "R" (914-6) | track toy
2009 911 Turbo 6-speed (997.1TT) | street weapon
2001 F150 Supercrew 4x4 | tow vehicle
Old 12-25-2002, 09:58 PM
bludden's Avatar
The VDO gauge I just got running has the lamp power as a seperate terminal at the top of the gauge.
Other than that you are correct. G is for the wire from the G (gauge I assume) terminal on the sender. Earth symbol is ground, and + is 12v switched (accessory). That way you will get a reading even if your lights are off.
I hope you have as much fun watching your oil pressure go up and down as I do!
Brian Ludden
Charlotte NC
'76 914
2k2 VW New Beetle Turbo S
Old 12-26-2002, 06:50 AM
