Sail panel trim
How does bottom sail panel trim come off?
Old 07-24-2016, 04:24 AM
Cairo94507's Avatar
I believe, if memory serves, it has pins on the back that push into the holes where the sail panel meets the quarter panel and the end tips just slip under the end trim on both ends. Be careful prying it loose, it is very easy to bend it.
'71 914-6 #0372
'17 Macan GTS
Old 07-24-2016, 05:43 AM
Control Group
Tobra's Avatar
the piece at the back has a screw at the bottom, the one on the bottom has little clip deals. Will take a pic later as I have mine off right now. When you put the vinyl back on, you want to leave it a bit long, and trim along the bottom with a razor or exacto knife as it will eventually shrink. It is glued on
Old 07-24-2016, 07:37 AM
