change door handle
can you take the lock out of old door handle and put in new one thanks
Old 07-21-2016, 04:17 AM
beatnavy's Avatar
Yes. You can also rekey the existing tumbler to match all the others on the car (other door, trunk, frunk, and glovebox) if you would like. I did this a couple of months ago (well, I didn't mess with the frunk or glovebox). Once you get the door panel off it's not too hard to get the door handle off and disassessmble it. Just be careful when you pull the tumbler out of the door handle assembly or you may lose those little spring-loaded wafers inside the tumbler. 914Rubber also sells a "kit" that is helpful for refurbishing the inner seals and pieces of the door handle.
Rob C.
'72 914 2056
'75 914 Project
Old 07-21-2016, 07:57 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
We have Technical Articles on the subject:
Porsche 914 Outer Door Handle Replacement | (1969-1976) | Pelican Parts DIY Maitenance Article
There is a link in there to another article about re-keying the door locks, as well.
If your old handle is broken, but the key still works, it is trivial to put the lock cylinder from the old handle into the replacement handle. Just put the appropriate key in each lock to keep the wafers and springs from flying out.
--DD
Old 07-21-2016, 11:19 AM
Wyvern's Avatar
As said ... YES .
I used the tech article here on Pelican (Thanks), with new handles, wafer kit to re-key and it was a fairly simple job....
2 points don't overt tighten the handle hardware and get some new door panel clips, as that needs to come off to do the job.
I had never re-keyed anything and now all my locks us ONE key . great fun, rewarding weekend job
Brian
Old 07-23-2016, 02:43 PM
