Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 914 & 914-6 Technical Forum
911 combo gauge
Hi can anybody tell me if the 911 oil temp/pressure gauge will work on a 914? I already have two separate gauges for this but would like to tidy it up. If so is it a direct fit and plug and play or are there mods required? Also is there a preferred 911 year?
Thanks, Joe
Old 07-26-2016, 11:39 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
It does fit.
There is no oil pressure sender in the 914 engine--the existing sender is just a switch, turning the "idiot light" on or off. There are pressure senders available; get the "dual sender" so you run both the light and the gauge.
Some 914s have temp senders in the "taco plate" (the left-front sump plate), but some do not. Adding one cleanly can be a bit or a challenge unless you get the stock parts. Most 914s have a wire to carry the signal for the temp sender, but not all do.
You need to make sure that you get senders that match your gauges, unless you can remember to ignore any actual numbers on the gauges.
You may need to run a wire for the temp gauge signal; you will need to run one for the pressure gauge signal.
You will lose your fuel gauge, unless you make other provisions. (E.g., a "triple gauge", or aftermarket fuel gauge, or re-locating the stock one somehow.)
--DD
Old 07-26-2016, 11:57 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Thanks Dave, I do have the dual sender and a taco plate sensor. So just wondering if the readings will be correct or do the sensors need to be changed out? and if so are these available?
Thanks, Joe
Old 07-26-2016, 12:38 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Administrator
Depends on which sensors you have. I'm not sure which range the stock temp sensor covers; if it is the same range as the 911 gauge (same temperature/resistance curve) it should be at least close. The oil pressure sender will have a pressure/resistance range, and it will have to match the gauge if you want correct readings.
The good news is that the range of resistance seems to be pretty standard, at least for some of the more common VDO senders. So if your sender is (for instance) a 350F sender, there's a good chance it matches with a 0-350F gauge; and a 5-bar (0-75 PSI) pressure sender should match pretty well with the 911's 5-bar gauge.
You still have the fuel gauge problem, though.
--DD
Old 07-26-2016, 02:09 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Puny Bird
Mark Henry's Avatar
I'm making my own combo gauge. Here's what I have so far, still have to add some idiot lights and repaint the face.
Just showing you my solution to the gas gauge issue, that's a 911 unit.
'74 Porsche 914, 3.0/6
'67 Bug, 2600cc T4
'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 07-26-2016, 02:54 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Emo993's Avatar
Thats great Mark, show us the final product when done. Would you make this for sale.....Mark
Old 07-28-2016, 06:46 AM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
fetus's Avatar
Check out members vendor in 914world. John sells a 904 style gauge made out of a 914 fuel gauge.
914World.com - The fastest growing online 914 community!
Old 08-16-2016, 06:18 AM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
echecsqueen's Avatar
I have a similar question. I have a 914 -4, 2.0 engine in my 1966 912.
The gauge is a 911 combo gauge euro
911 641 103 29
that has 1- 10 bar of oil pressure
Which sender should I use? This is where I need to put the dual sender
Lastly - what do I need to adapt the fitting I have now to accommodate the sender.
Thanks in advance
Q
1988 911 Coupe Granite Green "Frogger"
1966 912R Coupe Stone Grey outlaw -"'Tilda"
1978 924 White with Cork (Streetcar vs. Porsche - streetcar won)"Poindexter"
1984 924s Nile Green Metallic with bone (totaled it in the snow in Cleveland, Ohio)
1983 911 White with Cherry Red...gave away (not enough time or money to keep it running) in 2001
Old 07-09-2017, 06:19 PM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
Banned for Life
RSBob's Avatar
Echecs, go to 914 World, see link above and do a search or post your question. Very accommodating group there too.
Rick S, '71 914 3.0, '82 911SC
Old 07-10-2017, 09:05 PM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
Old 07-13-2017, 10:18 AM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
