Replacing brake hoses
I am replacing the brake hoses with s.s. braided lines. How the heck do you undo the upper hose on the rear sets. I can't seem to get my wrenches up there. I just want to make sure I don't damage the tubing. Thanks:confused:
You can remove the clip that holds it to the body. This should give you a little more room to get a good flare wrench on it I think it is a 17mm on the big end.
Be very carefull removing the steel lines, the flaring is usually stuck and the steel lines brake very easily
| All times are GMT -8. The time now is 10:11 AM. |
