-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   head temp sensor (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/92773-head-temp-sensor.html)
marv914 01-02-2003 12:48 PM
head temp sensor
The P.O. of my car swiched to carbs. Can the head temp sensor still be used be used ? If so can some one describe how to hook it up.
Marv
John Rogers 01-02-2003 01:15 PM
If you stay with the carbs the head temp sensor would not have much purpose. To connect it with a temp meter you'd need to find a meter that has a matching resistance range of the sensor. I don't know if anyone has tried that??? The VDO head temp setups use a matched meter, sensor and wire harness and fits to a spark plug. Good luck.
Dave at Pelican Parts 01-02-2003 01:45 PM
Funny enough, you can use a stock oil temp gauge with the FI's head temp sensor. It will read--something. You'll get "hotter" or "colder" readings appropriately, though you'll have no idea just how hot or cold the head really is. Just like the stock oil temp gauge--and about as useful.
Note that the aftermarket VDO head temp gauges work on a different principle alltogether and cannot use the stock FI's sender.
--DD
