Stock 914-6 oil union leak
My stock six won't stop leaking at the union between hard line and rubber line
that attaches to the oil tank. Is there a known fix for these fittings? Is the hard line more suseptable than the rubber fitting? The stock fittings are aluminum with thedate on them. My car is numbers matching 1971 which I'm trying to keep as close to orig. as possible. Thanks
67 275/4 63 B coupe 64 SC sunroof 912 coupe (current) 914/6 (current) |
