ack_tm's Avatar
Speedometer ticking?
My speedometer ticks.... actually, what is happening is the speedo needle twitches and when it does, it makes a relatively loud ticking noise... any suggestions?
ACK!
Old 01-04-2003, 11:13 PM
chrisreale's Avatar
Probably needs to be cleaned up and re-greased. Mine takes a bit to get it moving, and then it snaps up to the proper speed. It also stutters a bit.
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/
www.914club.com
Old 01-04-2003, 11:55 PM
Barber Dave's Avatar
Thumbs up ticking speedo
I would suspect the speedometer cable. You use to be able to buy a kit to lube cables. ( graphite I think) But It would be just a much work to replace it. Clean the head ,if noise is still there replace the cable. As lubing would be a temp. fix. Dave
Old 01-05-2003, 01:23 AM
pbanders's Avatar
Send a message via Yahoo to pbanders
It's likely you need a new cable. Check to make sure that the cable is completely set in the speedo, it's possible for the lock ring to be loose and the cable to work out of the speedo. Also check the speedo drive on the tranny and make sure the cable is snug.
I was just in my speedo yesterday, I fixed a problem that I've had with my car for 20 years. My trip odo reset was extremely hard to turn, the shaft at the mount under the dash had siezed. But after removing the c-ring, cleaning and re-greasing, it turns with no effort. Only took me 20 years to get to it .
Old 01-05-2003, 06:53 AM
Bruce Allert's Avatar
Brad... that's cuz it din't have nutt'n 'lectrical hooked to it
bruce
Sit'n here
Hav'n a beer.
Punkin's gone
(sniff)
Gotta mow the Lawn...
Old 01-05-2003, 07:51 AM
