-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   relay (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/931182-relay.html)
sixbanger 10-05-2016 11:44 AM
relay
quick question about the dual relay on a 74 teener. When checking for 12v at 88 b and 88d should it be across these two or at each and black lead to ground.
Dave at Pelican Parts 10-05-2016 09:37 PM
At each and back to ground.
--DD
sixbanger 10-06-2016 04:46 AM
I've got power at the fuze but no power at the relay.
Dave at Pelican Parts 10-06-2016 03:13 PM
Trace the wires, then. Make sure that the power is emceeing from where you think it is. If so, you may need to find a broken wire.
--DD
