Bushings Poly, Delrin, stock ???
What is the best bushings to go with? Poly,Delrin,stock? I use the car for autocross 95% of the time. The 30 year old ones have seen better days. Don't have the money for bearing type. PLease help.
Old 01-13-2003, 04:26 AM
mike mueller's Avatar
Even tho I'm selling the needle bearing kit I'll still chime here and give you some honest advice since I understand the price factor is pretty stiff.....
Go with the "street" compound poly bushings that Pelican sells...just make sure the fit is not too tight on the a-arms and if doing the rear trailing arms, the shaft internal to the trailing arm.
Cut grooves on the inside of the bushing (I've used a Dremel in the past with a ball end grinder) Lube the daylights out of them with the poly grease that comes in the little yellow container.
Mike Mueller
914club.com
Old 01-13-2003, 08:51 AM
JmuRiz's Avatar
Thanks for the tip mike;
I just got some A arm bushings from Pelican, and when i got them I was wondering how to lube them up, since they are so stiff. I'll try that groove cutting trick and pack them full of lube.
Nathan
'74 911 with '83 SC engine
'73 2.0 914 (2.7 /6 conversion in progress)
'64 356SC
'02 S6 Avant
'99.5 A4 2.8 / '65 Ducati Falcon 80
Old 01-13-2003, 11:09 AM
Never left, but not right
Zeke's Avatar
I didn't get no stinkin' grease w/ my order. Boo hoo.
Old 01-13-2003, 12:08 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
I'd call and ask for some...
--DD
Old 01-13-2003, 12:25 PM
JmuRiz's Avatar
Oh, I didn't get any grease with my order either...I was just going to use some grease I had. Could you use some Swepco CV/bearing grease? I also have some normal bushing lube in a grease gun too...what should I use? Thanks
Nathan
'64 356SC
'02 S6 Avant
Old 01-13-2003, 07:32 PM
Better use the grease formulated specifically for poly suspension bushings or they squeak like crazy...
'73 2.0 -- Yellow
Old 01-14-2003, 05:17 AM
JmuRiz's Avatar
Thanks, will do.
Mike - how far do you grind the channels into the bushings...I'm guessing just a little bit, but I want to make sure I don't go too far.
Nathan
'64 356SC
'02 S6 Avant
Old 01-14-2003, 09:13 AM
Nathan,
About 1/16th of a inch....
just becarful not to slip since that type of cutter can do some damage really fast on your fingers...
I used a bit similar to this one:
(everyone should have a dremel IMHO)
'73 914, 1.7, with Boxster transmission in the future?
Old 01-14-2003, 10:06 AM
