Center Cap Removal??
There may be a simple answer, but I need to know how to remove the chrome center caps from the wheels without damaging them. Any tips would be appreciated.
75 Sunflower Yellow 2.0
Old 01-20-2003, 05:49 AM
JWest's Avatar
Pull the wheel and carefully tap around the edge from the back side. Those things are softer than butter.
James
JWest Engineering
Old 01-20-2003, 07:30 AM
James,
Thanks for the advice. I will try that approach.
Randy
Old 01-20-2003, 10:27 AM
RETIRED
Joe Bob's Avatar
I use a wood dowel, and tap from behind. I have one that is large enough to fit tightly w/o binding.
Old 01-20-2003, 02:36 PM
Scott S's Avatar
You need two short pieces of thick walled PVC pipe - one that fits the inside diameter of the center cap one for the outside flange diameter. To remove, insert the smaller pipe into the cap and tap it out with a hammer. To install use the larger. Your caps will stay perfect. These are especially usefull with tire shops.
- A pile of British stuff
- A growing pile of German stuff
... oh, and two Hondas - complete with car seats and pounds of fish crackers smashed into the carpet (and seats, and door pockets, etc etc etc....)
Old 01-20-2003, 02:41 PM
Puny Bird
Mark Henry's Avatar
A kid at a tire shop will destroy all your caps in seconds!
Watch them like a hawk, or better yet, do the caps yourself!
Old 01-20-2003, 03:54 PM
jamcleod's Avatar
Send a message via AIM to jamcleod
did you see the listing on ebay from parts werks of chicago for the special tool to remove the center caps? i like the PVC idea.
Old 01-21-2003, 03:13 AM
Scott,
Thanks for the PVC idea. I'm off to Lowes for some PVC pipe today.
Randy
Old 01-21-2003, 04:24 AM
I went to the local Home Depot with a center cap in hand. I found 2 PVC caps that fit the center caps. One was an internal threaded one. I took that one and carefully sanded the inside until it fit the outisde of the cap. The other one I used my bench grinder to grind it down until it would snugly fit in the hole in the center of the wheel. They don't look to great, but they do the job, and it only cost about 5 bucks.
Clay Perrine
74 914 1.8L (Frodrick)
73 914 /6 4.0L 964 motor (Igor)
70 914 /6 Factory Six. (Elwood)
95 BMW 540i (Inga)
i always go to the same tire shop, with a window in the work bay. i always specify stick on weights on the inside of the wheel for balancing. the desk guy almost hit the alarm button when i saw one of their guys preparing to put HAMMER on weights on a set of fuchs and started banging on the window. close call.
kevin
Old 01-21-2003, 04:45 AM
