GA tech specs- spring rates?
Hey I'm rebuilding a GA 2.0 engine and need the following specs:
intake valve spring "open" tension___lbs @ ___"
intake valve spring "closed" tension___lbs @ ___"
exhaust valve spring "open" tension___lbs @ ___"
exhaust valve spring "closed" tension___lbs @ ___"
if someone with a manual could fill in those blanks, it would be GREATLY appreciated
thanks
Evan
Old 01-14-2003, 09:04 AM
