-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   engine assembly question-what type gasket sealer? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/94308-engine-assembly-question-what-type-gasket-sealer.html)
tshih 01-15-2003 04:55 AM
Tom wilson's book said Permatex 3H gasket sealer may be used for all engine sealing needs. I am going to seal the case halves with the sealant used for 911 cases (Locktite 574?). The thrucase bolt washers and oil pump gasket areas were other areas which I intend to use Permatex HYLOMAR HPF gasket dressing and flange sealant. Is this superior to the Permatex 3H in these applications? Anyone has actual field experience with these sealants?
Zeke 01-15-2003 06:42 AM
I used the 3H and the Hylomar where you indicated. I also used teflon sealant at the big end of the push rod tubes so they could move and not breadk the seal (hylomar) at the case. No leaks on break-in.
Jared at Pelican Parts 01-15-2003 08:10 AM
When I rebuilt my 2.0 I used Curil for the cases.
