Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 914 & 914-6 Technical Forum
Hand Throttle
Has anyone installed a Hand Throttle in their 914?
If so.......any pictures?.......references?
Looking into to assist warming up the engine before going on the track
Old 04-06-2017, 02:34 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
I've seen photos over on the 914world forum.
The bellcrank that the throttle pedal pushes on has an extra tab on the side of it. The hand-throttle has a rod that pushes on that tab. Friction in the hand-throttle lever keeps the throttle in place. That's really all there is to it.
--DD
Old 04-06-2017, 11:24 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
914-6 Hand Throttle
It is a very simple set up and easy to install...problem may be finding the parts!! You will need the Hand Throttle assembly (including the plastic knob); the special accelerator "tabbed" bellcrank end piece; metal rod w/fitting and the small metal piece that "holds" the rod suspended inside the tunnel between the hand throttle assembly and the bellcrank. Simple...but very effective for keeping engine revs up until normal operating temps! Good luck finding the parts!
Old 04-07-2017, 09:58 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Administrator
Here is one source:
porsche 914 914/6 hand throttles
Here is another source:
Hand Throttle
Pelican may be able to get one or the other for you; it's worth calling in and talking to Glenn Sager or Bruce Stone in our Sales department; both are 914 guys.
--DD
Old 04-07-2017, 10:30 AM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
porschetub's Avatar
Easy enough to make using the correct offset heater lever,you can take the throttle lever out and weld a tab to it easy enough ,the support piece for the rod is also easy to make,the hole is already there for it to bolt to @ the front of the tunnel.
I used a spare ball and cup I had off a old weber carb on the end of the heater lever.
I found it took more time to set it up than make it.
To finish off I painted the original knob with black paint.
They work well ,if your carbs are in good tune you don't need to keep it on long
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 04-20-2017, 02:49 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Tangerine racing makes one.
Old 04-26-2017, 09:42 AM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Administrator
Check the second link in my note above...
--DD
Old 04-27-2017, 11:08 AM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
