Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 914 & 914-6 Technical Forum
starter motor
Hi, Can someone confirm to me that I can use a starter motor from a Karmann or early bay in my 71 914, I have a USA car and finding parts in the UK is very testing, I'm sure it'll be okay but thought I'd ask the question before I spend my cash.
Cheer's
Old 06-05-2017, 01:39 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
The Bosch part number for the starter that fits the 914 is SR17X. Many parts catalogs have a different number which is incorrect.
A Google search for that part number turned up a page which said:
"Bosch SR17X starter will fit
1968-1979 Volkswagen Beetle
1968-1974 Karmann Ghia
1973-1975 Volkswagen Bus"
So it looks like you might be able to get it to work.
Note that the 73-75 Bus did use a Type IV engine similar to the 914's.
--DD
Old 06-05-2017, 08:43 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Tobra's Avatar
You can also use the starter for an early 911. It is a higher torque motor in a starter that is otherwise the same dimensions. By early 911 I mean the one that uses the same transmission, 901. It will cost a bit more.
Libertarians: Actively plotting to take over the world, so we can leave you alone
Old 06-06-2017, 02:27 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Horn issue
Thanks guys,
I found a lucas that match's and got a life time guarantee with it.result
I now have another issue,
The car arrived with the horn disconnected and now I'm trying to figure out how it goes back together.
There was no contact pin or rubber cap, I have purchased both (long pin) and fitted them as I thought they should be
I have a brown wire with white stipe that is live and connects to something but what? see pic.
Must be an easy fix? It's driving me mad.
Cheer's
Old 06-12-2017, 10:05 AM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Puny Bird
Mark Henry's Avatar
all the automatics use the 17x
'74 Porsche 914, 3.0/6
'67 Bug, 2600cc T4
'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 06-12-2017, 10:40 AM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Administrator
With a 71, there is a horn contact switch that is a separate part that goes in the steering wheel hub. I'm not familiar with the early setup, but what it will do is ground that brown/white wire. That completes the circuit through the horn, causing it to sound. The ground is generally provided by the steering hub itself.
Mark, please stop feeding the newbies disinformation. You know and I know that the "book" is messed up and says the 17x is sued by automatics only, but they don't know that...
--DD
Old 06-12-2017, 10:51 AM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Puny Bird
Mark Henry's Avatar
--DD
Disinformation? WTF are you rambling on about?
I was just stating the fact that the automatics VW's of that era all used the 17X. I was never even thinking of the one 914 sporto.
I guess I didn't clarify the VW bit, but the OP was asking if an early VW bus or Ghia starter will work... and it won't.
The 15x is not a self supporting starter.
IF you want to be a f'in ass wipe you are the one spreading disinformation google miester.
The correct starter for these cars (manual trans) is the 15x which no way in hell will work in a 914.
Now you can use a 17x in both these cars, but if the OP orders a starter for one he is very likely going to get a 15x which is NFG in a 914.
--DD
'67 Bug, 2600cc T4
'67 Bus, 2.0 T1
Old 06-12-2017, 05:53 PM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
Administrator
Thanks for the clarification. I really thought that the automatic thing was a complete mistake in the parts books! (And the automatic 914-4 not actually existing doesn't help.)
I did cite my source, and I can appreciate that it was wrong.
--DD
Old 06-12-2017, 08:25 PM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
