Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 914 & 914-6 Technical Forum
johnsonj
johnsonj's Avatar
L-Jet Wiring - 1976 914
I have begun working my 76.
The 2.0L has been removed and a 1.8L installed, with (yep) a single carb...
I plan to return the 1.8L to L-Jet (I have a complete L-jet set up for a 1.8L).
Will I run into any internal wiring issues on the relay board, etc...?
Thanks, any info is appreciated.
Jeff
Old 06-20-2017, 08:05 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Depends on how much of the FI parts you actually get. There are a few parts that you don't want to forget, like the resistor pack and the double relay. Both of those, I believe, hang off the battery tray for the 1.8 car.
The relay board and chassis wiring harness should all be the same between the 2.0 and the 1.8. There may be changes that were made when the carb conversion was done that you will have to undo, though. (Like fuel pump wiring, for instance.)
--DD
Old 06-20-2017, 08:41 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
johnsonj
johnsonj's Avatar
Thanks Dave.
I have all of the L-jet parts, glad to know I won't have to worry about the wiring too much.
Jeff
Old 06-20-2017, 09:16 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Banned from Boulder
Jrboulder's Avatar
L-jet gets ECU and fuel pump power through the double relay. You'll need to get one and wire in the body half.
You'll need to make the following connections:
88d to fuel pump power
86a to starter yellow wire
88z to non-switched power
86c to ignition coil 15
85 to ground
1976 Porsche 912E Grand Prix White
2013 BMW 328i Sport Line 6MT
Old 06-20-2017, 02:39 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
you never changed the relay board when you went to a carb, you just changed the 14 pin wiring loom. When you change back to FI the FI wiring plugs back into a connector on the relay board
Old 07-04-2017, 07:56 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
johnsonj
johnsonj's Avatar
Hi,
Thanks Jess.
The relay board wasn't removed by the previous owner, I don't anticipate any problems (or at least too many) when returning it to FI.
Jeff
74 914
76 914
80 911sc Targa
81 928 Euro
Old 07-16-2017, 09:40 AM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
