-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   914 not running on its own (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/962575-914-not-running-its-own.html)
keeganp2011 07-07-2017 04:44 PM
Hello my 914 only fires off carb cleaner I'm going to put a new fuel filter in it any other suggestions?
racer 07-07-2017 06:21 PM
Start with the basics.. Is it getting:
1) Air?
2) Fuel?
3) Spark?
Is it injected or carbed? was it running fine recently or is it a project you are trying to get started?
How is the fuel supply? Olg Gas? Gummed up from Ethanol in the fuel? old lines? bad pump? bad filter?
keeganp2011 07-08-2017 07:06 AM
1) Air?
2) Fuel?
3) Spark?
Has air and spark new fuel lines new fuel and it ran before winter
Sent from my SM-G900V using Tapatalk
RandyLok 07-08-2017 10:47 PM
You've ruled out air and spark. Need to know more about the fuel system. Djet? Ljet? Carbs? The troubleshooting methods are different.
keeganp2011 07-12-2017 04:20 PM
I'm going to be honest I don't know I've berly looked at it.....
keeganp2011 07-12-2017 04:24 PM
Is there any way to tell other than looking at it....it's in storage right now so I'm not able to walk outside and see it and I honestly don't know the difference
Dave at Pelican Parts 07-13-2017 04:36 PM
Ways to tell? Find pictures? See if there is documentation anywhere?
Trying to troubleshoot a car without actually seeing the car is difficult. Trying to do so where there isn't anyone who can look at the car is basically impossible!!
--DD
keeganp2011 07-13-2017 04:42 PM
--DD
Well I'm over there working on it but Idk the difference
rpc356 07-14-2017 06:02 AM
Keegan, since you have access to the car take some photos of the engine compartment and post them. Folks are willing and able to help, but you have to provide information. Do that and you'll start getting some good ideas of what to check.
keeganp2011 07-14-2017 06:04 AM
Okay thank you
racer 07-14-2017 06:54 PM
Fuel pump getting power? Fuel filter clogged? and as mentioned.. share some photos of the engine and we're happy to help!
keeganp2011 07-14-2017 07:01 PM
Yes I will share pictures next time I go I pulled the tank out and found that when I slid the tank back in after replacing the fuel lines we pinched one so it wasn't getting fuel but I bought a fuel filter to replace the old one
