Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 914 & 914-6 Technical Forum
fuel pressure
I have a two barrel weber carb on my 914 2.0 with a choke and it is missing sometimes. What is the fuel pressure for this carb. I am running a electric fuel pump
Old 09-15-2017, 09:38 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
It wants pretty low pressure, on the order of 3 PSI I believe. Make sure you're using a pump that delivers low pressure; the stock pump pushes way too much pressure and too much volume to be easily regulated down to that low.
Make sure the ignition is in good condition; often "carb problems" are actually ignition problems--or even compression or valve adjustment problems.
BTW, the single-carb setup is pretty much the worst possible way to get fuel into the engine. THe long unheated manifolds lead to fuel drop-out, manifold wetting, and often to uneven mixture distribution. If you must run carbs, run duals.
--DD
Old 09-16-2017, 05:35 PM
fuel pressure
what is the fuel pressure for set up
Old 09-16-2017, 08:57 PM
fuel pressure
sorry what is the fuel pressure for the dual set up
Old 09-16-2017, 08:59 PM
Administrator
Similar to the single, 3 PSI for most.
--DD
Old 09-17-2017, 12:08 PM
