Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 914 & 914-6 Technical Forum
list
Dave... Do you are someone else have a list of the serial numbers as to the year of manufacting and also the engine serial numbers as to the size with having to open them up. I have been told my car was a 1974 ,others said it was a 1975 and I am not saying what the title says.HAHA
thanks
Old 09-23-2017, 07:40 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Check the VIN. If it starts with "47429" it is a 74 model year car. If it starts with "47529" it is a 75 model year.
Note that production of a given model year starts in ~August the year before, so a 75 could be built in 8/74. That sometimes causes confusion when people look at the build date on the sticker on the driver's door jamb.
You can use the engine code to tell what the engine started its life as, but it is easy to build any given Type IV case into any stock displacement (or any of the common post-factory ones for that matter) so that is not a guarantee of the current displacement. The two options available in 74 and 75 are 1.8 or 2.0.
The 1.8 serial number should be on the upper-right of the crankcase near the flywheel end. You may have to push stuff out of the way and/or clean crud off the case to find it. It should start with "EC", which is the engine code for 1.8s.
The 2.0 serial number should be in front of the oil filler, between it and the fan shroud. There is almost always stuff to move out of the way to see it, and very often crud (old spilled oil etc.) to clean off. The 74 2.0 should start with "GA", and the 75 2.0 should start with "GC".
--DD
Old 09-23-2017, 09:50 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
