jrblackbox's Avatar
Will wheels with a 5" backspace fit?
Looking at buying some new wheels. They are 5.5 x15 with a 5" backspace. Will they fit my narrow body 914? TIA
Old 10-23-2017, 03:06 PM
racer's Avatar
Stock backspace, iirc, is 4.75" (4 3/4"). Fitment could be limited by tire choice (ie, a 185 might fit, a 205 might not), fender lip rolling, camber and ride height etc. Could also be an issue if the car was hit at one point and not repaired right.
Past:
2000 Boxster 2.7, 1987 944
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 10-23-2017, 05:29 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
They should fit, depending on tire size.
--DD
Old 10-23-2017, 07:22 PM
jrblackbox's Avatar
--DD
I have a set of 205/60 I was planning on using. Any possibility the fender would rub?
Old 10-24-2017, 02:19 AM
Administrator
Yes, there is a possibility. I do not think it is likely. Your rear camber will influence that, and possibly other things as well. There's a good chance you won't need to flatten or trim the fender lip, as is somewhat common with stock wheels and that size of tire.
Note that it's a whole lot easier to move your wheels outward in the fender using spacers, than to move them in toward the center line.
The tires would almost certainly rub in the inner front fender when the steering wheel is turned full lock. This happens with stock-offset wheels as well. Usually that only occurs at low speed, so most of us just accept it. Yours may be more severe.
--DD
Old 10-24-2017, 12:16 PM
