Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 914 & 914-6 Technical Forum
jrblackbox's Avatar
Trans leak at CV
In the middle of my 5 lug conversion. where the CV joints attach to the transmission, it appears that both sides have leaking/seepage. I have tried searching but I really don't know what I am looking for. Easy, or too much, not worth the effort, don't bother? Gaskets, bearings? TIA
Old 10-29-2017, 08:24 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Seals. You replace them by removing the axle flanges from the transmission. I haven't done this job with the trans together, so I don't know how difficult it is.
--DD
Old 10-29-2017, 09:27 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
jrblackbox's Avatar
Thanks Dave, part number?
Old 10-29-2017, 09:42 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Administrator
The PET says: "999 113 183 40 radial shaft seal 45 X 68 X 10"
Aftermarket, $5
OEM part
--DD
Old 10-29-2017, 08:36 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
84 911 3.2 Coupe
Arne2's Avatar
Piece of cake to do, no disassembly of the transmission is required. Unbolt the CV, there will be a bolt in the center of the flange. Remove it and pull the flange off. Clean and replace seal, put it all back.
- Arne
My car's blog-like thing: http://arnes.stuff.paunix.org/porsche/index.html
"Honestly now, did you spend your youth dreaming of someday owning a Nissan or Mitsubishi?" - Porsche ad from early '90s
Old 10-29-2017, 09:09 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
jrblackbox's Avatar
Thanks all!
Old 10-30-2017, 03:11 AM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now available:  101 Projects for Your Porsche Boxster!
Double Trouble
targa911S's Avatar
yep. easy job.
I used to be addicted to the hokey pokey..........but I turned myself around..
75 914 1.8
07 Dodge Caravan
Old 11-01-2017, 06:19 AM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
